Activity › Forums › Apple Final Cut Pro Legacy › Windows Photoshop File and Final Cut
  • Windows Photoshop File and Final Cut
    Posted by Mpowell on October 20, 2006 at 3:10 am
    When importing a windows photoshop psd into final cut studio on a mac, the file does not import as a layered sequence as it should. To get around this problem we opened the file on a mac with photoshop, simply saved the file and then when importing to final cut, everything worked as it should.
    Would like to know if there is a way to avoid having to do this step, as we don’t have photoshop for mac on the machine with final cut on it at present.
    John Pale replied 19 years, 11 months ago 3 Members · 2 Replies
  • Shane Ross
    October 20, 2006 at 5:29 am
    Nope. That is the fix I always recommend.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • John Pale
    October 20, 2006 at 5:57 am
    You might want to try installing Photoshop Elements on the Mac…its rather inexpensive.
