Activity Forums Compression Techniques Windows Media Widescreen…
  • Windows Media Widescreen…
    Posted by Jeffrey Gould on December 6, 2007 at 3:08 am
    Hi, I have a 720×486 SD widescreen project I’m exporting out of Premiere as a QT Movie highest quality. I need to compress to Windows Media at two bandwidths: 300kpbs streaming and a larger downloadable version. I have the latest version of Squeeze, my question is what size should I export my 720×486 project out of premiere and what should the resolution be of the streaming and downloadable versions in order to maintain the 16:9? I did a search and couldn’t find anything relating to Widescreen. I’d appreciate some direction….thanks.
    Jeffrey S. Gould
    Action Media Productions
    Jeffrey Gould replied 18 years, 9 months ago 3 Members · 12 Replies
  • 12 Replies
  • Dan Wharmby
    December 6, 2007 at 5:10 am
    Hey,
    I’ve had good luck using 854X480 @30FPS as a download and 480X270 15FPS for a preview. I also save a little bandwidth by mixing down to 44.1 and mono audio. Hope that helps.
    Daniel Wharmby
    Compressionista
  • Daniel Low
    December 6, 2007 at 11:01 am
    Daniel;
    Being picky; both settings are not equally divisable by 8 (or 4) on both axis.
    I guess it was a typo on your part but the horizontal dimension on the first setting (854) is actually larger than the source dimension (720). Enlarging the video is last thing you’d want to do!!
    Anyway, back to Jeffreys post –
    Export out of premiere at full resolution – 720×486 using the source settings.
    For the 300Kb/s stream I’d look at a frame size of 384×216, or if you want to push it 448×252 which is divisable by 4 but not 8.
    For the high quality download I’d plump for a frame size of 512×288 or 640×360.
  • Jeffrey Gould
    December 6, 2007 at 2:09 pm
    Danny, yes the output would be greater than the source. Your suggested sizes are perfect, but I ended up using 432×240 for the streaming, I’ll use 640×360. Appreciate the replies…great forum.
    Jeffrey S. Gould
  • Jeffrey Gould
    December 6, 2007 at 3:42 pm
    I do have one additional question: what bandwidth setting do you go with for downloadable files, I don’t see any presets in Squeeze. Thanks.
    Jeffrey S. Gould
  • Daniel Low
    December 6, 2007 at 3:53 pm
    It really depends on the complexity of the content and the quality level you hope to achieve and yet still have a reasonable file size.
    For 640×360 I’d suggest starting at 700Kb/s and work up from there. Remember for download files you can use VBR, if you have the time make sure it’s 2-pass.
  • Jeffrey Gould
    December 6, 2007 at 6:14 pm
    Can’t thank you enough, file came out to be around 60mb, not sure if that is an acceptable size for viewers to download, but it’s large and looks great. Thanks again.
    Jeffrey S. Gould
  • Daniel Low
    December 6, 2007 at 7:49 pm
    60MB….well it all depends how long the clip is!
  • Jeffrey Gould
    December 6, 2007 at 8:09 pm
    It’s 9 minutes long…Nature Video on Birds. They also have the streaming one on the same page if they choose. I know I’ve downloaded QT movies around that size of peoples demo reels from the Cow…I guess if you’re interested enough, it’s worth your time.
    Jeffrey S. Gould
  • Dan Wharmby
    December 6, 2007 at 8:22 pm
    Danny,
    Whoops. Yep, bigger than the source. I’ve been exporting HDV all day. Thinking in 1080. Thanks for the catch.
  • Daniel Low
    December 6, 2007 at 9:37 pm
    Can you post a link?
