Activity › Forums › DaVinci Resolve › Windows / Mac project compatibility
Posted by Andrew Sableton on October 6, 2011 at 12:16 amWondering if anyone knows it will be possible to grade on a windows Resolve and then transfer the project to a Mac Resolve and render out there?
A.S.
Dane Cannon replied 14 years, 11 months ago 5 Members · 5 Replies -
Peter Chamberlain
October 6, 2011 at 12:24 amThe Linux, Mac and windows all use the same DB file structure so interchange works without problems.
Peter -
Margus Voll
October 6, 2011 at 5:55 ammedia could be the problem. i.e. prorez on windows etc. one just has to test workflow out.
simplest would be to use uncompressed media if machines can handle it.
Margus
Andrew Sableton
October 6, 2011 at 4:01 pmWe will be moving from FCP workflows to Avid so I presume that AVID DNxHD will work fine cross platform (not going to be attempting to integrate imovie Pro)
Rohit Gupta
October 6, 2011 at 4:10 pmYes, DNxHD support is the same across all 3 platforms – Mac/Windows/Linux.
Dane Cannon
October 6, 2011 at 4:41 pmWill there be a solution for Prores on a mac? Perhaps a license like the DNxHD one?
