Activity › Forums › Adobe Premiere Pro › windows install project vanished
Posted by Steve Bleasdale on July 7, 2017 at 6:44 pmI had to install fresh windows 7 pro version 64 bit and had a project cs6 to finish so backed up as normal and after a restore on my computer the project has vanished but all the media cache files are there, help how do i re-link everything. Steve
Paul Neumann replied 9 years, 1 month ago 5 Members · 10 Replies -
Ann Bens
July 7, 2017 at 8:03 pmMedia cache wont help.
You need the orininal footage and project.
If you had everything stored in Documents which is default on the C drive then most likely eveything is gone.
Where did you store your backup.———————————————–
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional -
Brent Marginet
July 7, 2017 at 8:32 pmWhen you do a clean Windows Install you should not do a restore.
That can negate the clean install by putting back old files, drivers, Registry Entries, etc, etc that you don’t want back.
That would mean either backing up everything you need to an external HD or installing the OS on a new boot drive.
The Project may not have been stored in a location that Windows backs up by default.Wow, no secondary USB, Hard Drive, Dropbox or backup anywhere else.
So starting your project from scratch would be the only way then.Read My Media Moto below and Apply that to all of your projects as well.
I know you want to cry but really, WOW, no extra backups.\”MY MEDIA MOTO: If you think three copies of your media is enough.
Take a moment to place a value on it and then maybe add two more.
Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\” -
Steve Bleasdale
July 7, 2017 at 8:54 pmi have 4 externals and saw the projects on the externals in two of them when i backed up, but when i completed the fresh install of windows 7 pro 64 bit they have vanished leaving behind the media cache and all the video files. some other projects are there but not two i flaming need, they must be somewhere.
Chris Wright
July 8, 2017 at 3:21 amIf you didnt format or Delete partition, your old files might be in windows.Old users documents. If not, time to install easus data recovery.
Steve Bleasdale
July 8, 2017 at 5:01 amTop man my friend thank you I just noticed the restore has created two new partitions F and G now when I click on them they show nothing but they have something in them because they are half filled with blue lines. Maybe avrecover program can see what’s in the partitions? Long shot
Steve Bleasdale
July 8, 2017 at 6:03 amFound it, thanks to all you guys, for some reason it was hidden in another persons folder? weird but all i have to do is link media PHEW PHEW….
Brent Marginet
July 8, 2017 at 6:17 amThat’s fantastic, that must be quite a relief.
I do still stand by not doing a restore after a clean OS Install.
I’ve seen this cause far to many problems in the past.
On the plus side, I have been handsomely paid fixing other peoples systems a few times after a restore destroyed there OS.\”MY MEDIA/PROJECT MOTO: If you think three copies of your media or project are enough.
Take a moment to place a value on them and then maybe add two more.
Steve Bleasdale
July 8, 2017 at 6:34 amCheers guys i cannot thank you enough thanks everyone and Chris top man…..Steve UK
Highlighted all clips in panel and rick clicked link media and its all linking phew phew phew…. I just never gave up because i knew it had backed up properly to external hard drives….. -
Paul Neumann
July 9, 2017 at 12:39 amAnd now a word about Creative Cloud and all the Premiere, Audition, After Effects and Prelude projects I have that are automatically backed up and synced to the cloud storage….word.
