Activity › Forums › Avid Media Composer › Windows Drivers for the Avid Targa 3000/3100
Posted by Jason Roberts on September 10, 2008 at 9:16 pmI recently acquired a set of Avid Targa 3000/3100 video capture boards.
Checking if anyone on the COW forums has access to Windows (NT/2000/XP) drivers for these cards?Mark Godwin replied 1 year, 10 months ago 7 Members · 15 Replies -
Jakob Viggo hansen
November 27, 2008 at 10:47 amHi Jason,
Being on a similar quest to yours, i’ve located drivers for the 3200 board, which I think is sufficiently similar to the 3100 to work.
They are version 2.4 for Win2K.
Please note: these drivers are not specifically intended for AVID. I think they’re generic?
Drop me a line, if you’re interested.
Kind Regards
Jakob -
Jason Roberts
November 29, 2008 at 2:43 amJakob, Thanks a bunch for your email. I certainly could use the drivers. my email address is jason.robertssiii@gmail.com
Gerry Lawson
December 21, 2008 at 1:06 pmHi Jason,
I just picked up one of these boards from EBay and managed to track down the drivers for the Targa 3000. I tried to email you but the address from your above post bounced back at me.
For many of the drivers try the links at the following website.
I know long url.
Some links are broken. You can try the following for the Targa 3000 1.51 driver
https://cdn.pinnaclesys.com/SupportFiles/T3k_1_5_1.zip
Please let me know if these drivers work for you and what hardware you are using with the 3100 board.
If you have any troubles let me know and I can upload the drivers somewhere.
cheers,
gerry -
Jason Roberts
December 23, 2008 at 4:34 amHullo Gerry,
Thanks a bunch for getting me these drivers, I really appreciate your efforts.
Remember anytime you find yourself in the metro Vancouver area of British Columbia you have a friend you can count on.
Cheers
JR
Gerry Lawson
December 23, 2008 at 6:23 amHi Jason,
Funny you should mention… my car could use digging out 😉
I live near Fraser and King Edward in East Van.
Let me know how the drivers work out – I should be getting my card around New Years.
gerry
Andras Anderson
June 11, 2020 at 2:39 pmHello sorry to bump the subject after twelve years but it’s the only place have seen where i can find the targa 3200 driver, is by any chance that anyone still have the driver ?
Piotr Gliźniewicz
October 28, 2021 at 12:13 amFor anyone bumping here in the future: this is the archived version of the 1.5.1 drivers: https://web.archive.org/web/20120215202210/http://cdn.pinnaclesys.com/SupportFiles/T3k_1_5_1.zip
Mark Godwin
November 1, 2024 at 6:30 pmThanks a lot for archiving these drivers. I got two Targa 3000 with Digital Tether port, but I have real issues about the computer system where they can be fitted. I’m trying on a old HP XW8000 dual Xeon workstation who has 64 bit PCI slots. Can you tell me the computer specifications where you using the Targa 3000?
Mark Godwin
November 2, 2024 at 6:50 pmWe are in 2024 but I’m still trying to get my Targa 3100 working. I have no luck. As I launch Discreet Edit 6.5 , it does not find the hardware and crashes. Same for Premiere 6.5, it crashes after some loading. I have Targa drivers 1.5.1 , the workstation is an HP XW8000 Intel E7505 chipset, dual Xeon 3.2 “Gallatin” CPU , 4 GB of Ram, ATI X1950 Pro VGA AGP and T3K is inserted into one of the 64bit 100MHz PCI-X slots. The driver installation process itself is fine but as I launch any application supporting Targa hardware, it crashes! The Targa Board Monitor and system test running just fine without issues…Maybe I do need an older computer with different chipset/processor? Maybe I have a memory conflict? How to fix? In the system BIOS there is not so many parameters. Thanks for who will read and spend a word.
Mads Nybo jørgensen
November 10, 2024 at 10:42 pmHey Mark,
I loved the old *edit system, but AtoDesk/Discreet killed it – never forgiven them for putting 2 of my editing suites on the scrap-pile, without offering an alternative.
Anyway, water under the bridge.
Are you on Windows NT?
Sounds a bit crazy, but have you thought of getting a “spare” on eBay?
There is a link on this posting to a 3100 card:Maybe do a call-out, I don’t know where, but there is still some of the people lurking around who used to work for companies that did the integration and technical support of *edit systems.
Avid has recently got new owners, and a lot of people left the organisation, maly for retirement. But maybe Avid has the drivers and documentation on a shelve, or would know a specialist internally (employed or retired) that might be kind enough to help you.
The obvious question is how much money you want to spend v Return on that Investment?
I’ll keep a look out as I may still have some of the old CD-Roms lying around, byt my systems was Targa-2000, so can’t promise. Adding, that these days I am in the habit of throwing out drivers that I no longer need.
Hope this helps?
Madsebay.com
Pinnacle Truevision, Targa 2000 RTX/DTX, Targa 3100 (or SDI), MADRAS, Targa + | eBay
Targa 2000 SDXSDI Serial Digital I/O NTSC/PAL Motion JPEG Compressed (4:2:2) Dual Video Stream Capture Card (PCI Bus) provides Serial Digital Interface Video I/O and AES/EBU Digital Audio I/O. Will also provide S-Video and Composite Out which are usually used … Continue reading
