Activity › Forums › Apple Final Cut Pro Legacy › Windows become Transparent after moving or using items
Posted by Gobananas on December 26, 2006 at 6:31 amHi,
I don’t know why i have this problem but if an item (still or video) becomes idle, or if i click it a or highlight an item in my timeline or browser, it becomes transparent and I can see my desktop.Is there any way to fix this?
David Bogie replied 19 years, 8 months ago 4 Members · 6 Replies -
Bouncing Account needs new email address
December 26, 2006 at 5:40 pmThe first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
Next:
THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
“Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”Click the following link for instructions.
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.Download these free Apple Scripts at
https://fcprescue.andersholck.com/
or
https://pistolerapost2.com/fcprescue/This is one FCP tip that has helped in solving hundreds of “odd” problems.
Bret Williams
December 26, 2006 at 7:35 pmAre you running windowshade by Unsanity? That’s the only control panel I know of to make windows transparent. Might need to update version or turn it off if you are.
David Bogie
December 26, 2006 at 8:46 pmAside from trashing FCP’s prefs files, such behavior usually points to OS issues or graphics card problems. You need to figure out if it happens in any other applications that pull on the CPU and GPU as hard. Start by repairing permissions (like FCP prefs trashing, can’t hurt) and then trying FCP again. You can also try booting your Macintosh from the installation disk for OS10 and running disk utilities. Can’t hurt. If it persists, you may want to go as far as resetting the page management unit button on the motherboard. Mac OS online help has the PMU instructions, I believe.
bogiesan
Gobananas
December 27, 2006 at 4:42 amThank you, i deleted shapeshifter which was included with unsanity, and now my fcp runs well! who would have thought!!
Bret Williams
December 27, 2006 at 4:43 amThat’s the power management button, and if your computer is running, the pmu probably has nothing to do with it. If you mess with the pmu, read everything you can. If you hold this button too long, you can truly screw things up.
David Bogie
December 29, 2006 at 3:37 pm> Are you running windowshade by Unsanity? That’s the only control panel I know of to make windows transparent. Might need to update version or turn it off if you are.< Interesting grasp of the situation, Bret. I would have never thought of that because I would never install weird apps like that on my editing machine. Also, interesting that you could see "transparent" as a user-caused issue and not a graphics card or OS problem. I was thinking of certain display glitches I think most of us have seen on our Mac monitors at one time or another where a restart cleans it up. Ever seen those endless trails behind a window when you move it around? Good call, bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
