Windows 7 for VEGAS 10
Posted by Thomas Lenler-eriksen on October 5, 2010 at 6:55 amHello.We have been using Windows XP for our PCs for a while but now we want to upgrade it to Windows 7. We are using Sony Vegas Hd 10 Platinum (Production Suite) and it wont run properly with Windows XP. So we are installing Windows 7 to get more power. But alas there are 6(?) versions of W7, so what I want to ask You about is: Which version will be the best for Sony Vegas Hd 10?
Kind regards
Thomas
David Rossi replied 15 years, 10 months ago 5 Members · 8 Replies -
John Rofrano
October 5, 2010 at 10:33 am[Thomas Lenler-Eriksen] “But alas there are 6(?) versions of W7, so what I want to ask You about is: Which version will be the best for Sony Vegas Hd 10?”
They are all good for Movie Studio HD… the question is which one is right for you? I use Windows 7 Home Premium and it is fine for my work and allows for up to 1 CPU with unlimited cores and 16GB of memory. If you have 2 physical CPU’s you will need Windows 7 Professional.
If you have 2GB of memory or less, install the 32-bit version. If you have 3GB of memory or more install the 64-bit version.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Ron Bakker
October 5, 2010 at 4:07 pmYeah I got the 64bit option purely so I could run more memory.
Pentium 2.4 quad|Asus P5G41C-M LX mobo|2 gig corsairs 6400 ram|Corsairs 630 power supply|Gigabyte 8800gt|2x seagate 500gig Hd’s|Lg dvd burner|windows7 premium , SV9E
October 5, 2010 at 6:06 pmThank You for your fast answers. I will install an Ultimate version tomorrow.
Thomas
October 6, 2010 at 7:14 pmHi
I have changed the os to W7 Ultimate but now I got a problem when I want toinstall vegas.
“Error: 1603” keeps coming up and I cant install Vegas. I’ve tried W7 Pro N too and it is the same result. Is anyone aware of what Error: 1603 is all about?Kind Regards
Thomas
Stephen Mann
October 6, 2010 at 8:59 pmThis is a windows error. Did you do a fresh install or an upgrade? Are you running the install program as administrator?
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
John Rofrano
October 7, 2010 at 2:36 amyea definitely a Windows error. You can read about it from Microsoft here:
https://support.microsoft.com/kb/834484
~jr
October 19, 2010 at 10:09 amHi.
It was a windows error. Its working now,
and W7 professional and 8gb made Vegas much faster.
Thanks a lot for your help.Kind regards
Thomas
David Rossi
November 27, 2010 at 5:33 pmCiao Thomas i’m David from italy , i’ve the same problem error 1603 at the end of installation , what’s the solution ? Saluti D
