Activity Forums Blackmagic Design Windows 5.7 motion jpg issue
  • Windows 5.7 motion jpg issue
    Posted by John Baum on September 26, 2006 at 3:17 pm
    Just installed the 5.7 drivers and was trying out the new MJPG codec. The capture I made going from a Beta SP deck through the component in has a strip on the right side about 10 pixels wide where the luminance is much brighter. On the scope it looks like about a 10 IRE shift.
    I recaptured using the uncompressed codec and it looks fine.
    Luke Maslen replied 20 years ago 4 Members · 7 Replies
  • 7 Replies
  • Luke Maslen
    September 27, 2006 at 7:04 am
    Can you try the capture again? We’ve been capturing from Betacam SP UVW1800 with no problems and an external beta tester has also been doing this for weeks with no problems. I can’t understand how the codec would be involved and suspect it might be some other technicality.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Wolf
    September 27, 2006 at 11:11 am
    Hi Luke,
    i tried also 5.7 and it
  • John Baum
    September 27, 2006 at 5:08 pm
    I tried it several times with the same result. It looks exactly like the screengrab Claus-Peter posted.
  • Deleted User
    September 27, 2006 at 9:49 pm
    Hello,
    If I render from an uncompressed 10 bit 4:2:2 timeline with 10 bit uncomporessed 4:2:2 files to the MJPEG when I want to master the video down as a backup. I get teh same problem precious a line going up the right side of the screen with a higher lumiance value.
    Leo
  • Luke Maslen
    September 28, 2006 at 6:40 am
    Hi Ghobii,
    Many thanks for your reports. We’ve replicated the problem and hope to have a driver update to fix it in the next couple of days.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Luke Maslen
    September 28, 2006 at 6:42 am
    Hi Claus-Peter,
    Thank you for your very helpful screen print. We’ve replicated the problem and hope to have a driver update to fix it in the next couple of days.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Luke Maslen
    Hi Leo,
    Nice work! Thanks for your report. We’ve replicated the problem and hope to have a driver update to fix it in the next couple of days.
    Regards,
    Luke Maslen
    Blackmagic Design
