Activity Forums VEGAS Pro Windows 10
  • Windows 10
    Posted by Robert Engle on June 4, 2020 at 11:56 am
    I have Vegas Pro 13 and have used it mostly problem free besides the occasional lock up. I just recently upgraded to Windows 10 and am doing a small project this morning for the first time since upgrade and it has stopped working or locked up 4 times??
    Is this not compatible with Windows 10 or another issue?
    Thanks Bob
    Steve Rhoden replied 6 years, 3 months ago 4 Members · 4 Replies
  • Steve Rhoden
    June 4, 2020 at 10:24 pm
    It locked up because Vegas 13 is a bit too old to work efficiently in Windows 10.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Mike Kujbida
    June 4, 2020 at 11:46 pm
    I’ve been using Pro 12, 13 and 14 with Windows 10. No problems here.
  • Christian Wheel
    June 5, 2020 at 5:18 am
    It certainly works with Windows 10. But when you upgrade your OS there’s a lot of garbage from your old version that gets left behind, including codec fragments which could be causing your problems.
    First thing I’d do is uninstall any codec packs and then reinstall them fresh if you need them.
    If you still have problems, you might have to bite the bullet and do a fresh Windows 10 install. It sucks, but it’s a panacea for a lot of these issues that arise out of upgrading.
    —– Christian Wheel —–
    Radio Host, Los Angeles/San Diego/Nationally Syndicated
    Audio Production & Imaging
    MS Visual Studio Developer
    After Effects Enthusiast
  • Steve Rhoden
    June 5, 2020 at 5:36 pm
    The best option i would recommend is upgrading Vegas Pro also. Since you already upgraded Windows, that should be your next logical step for an efficient workflow….. But make sure you remove/uninstall everything Vegas before you do the new upgraded install.
