Activity › Forums › DaVinci Resolve › Window time code
Window time code
Posted by Mark Shumard on July 9, 2013 at 9:32 pmResolve is rendering window time code onto the video. How do I turn this off?
Mark Shumard replied 13 years, 2 months ago 2 Members · 2 Replies -
Dwaine Maggart
July 9, 2013 at 10:05 pmIf you don’t want to see any burn ins at all, turn them off in the Data Burn In area on the Color page.
If you just don’t want them to be rendered, on the Deliver page, select None for the “Data burn in preset”.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Mark Shumard
July 10, 2013 at 1:09 amThank you for your help! I’m new to Resolve and it’s a really steep learning curve. I’d been searching “window time code” on the DR forum but was getting only info on how to use time code. You didn’t tell me where to find the check box but you did give me the right word, “burn”. I word-searched “burn” in the PDF manual and found I needed to go to a “palette”, word-searched “palette” and found a palette that has a flame icon (duh … must be burn) and there was the check box! Thanks again for your help!
