Activity › Forums › Web Design (WordPress, Joomla, etc.) › Window resize moves stuff in IE, but not Firefox
  • Window resize moves stuff in IE, but not Firefox
    Posted by Plusch on February 2, 2006 at 5:34 am
    Hi, all
    Any help with this would be greatly appreciated. Here’s the example with the problem:
    https://www.michigantoday.net/home_paul_new-05.html
    This page works fine in Firefox 1.5. As you resize the browser window, the page stays horizontally centered, with everything where it belongs.
    In IE6, though, resizing the window causes everything to stay centered except the navbar and the subtitle above it. They appear to slide horizontally with respect to everything else on the page.
    The navbar is a drop-down menu built in Fireworks. I’m viewing on Windows 2000.
    Paul
    Curtis Thompson replied 20 years, 7 months ago 2 Members · 1 Reply
  • Curtis Thompson
    February 6, 2006 at 2:50 pm
    hello…
    definitely check these 2 styles at the top:
    – subhead
    – FWTableContainer1501158286
    made a local copy of your file and if i rename/disable those 2, the content moves in ie/windows as it should. i didn’t poke into your css much, but you likely have some positioning code that is causing that to happen…
    sitruc
