Activity Forums DaVinci Resolve Window Outline shortcut strangeness – and feature request
  • Window Outline shortcut strangeness – and feature request
    Posted by Laco Gaal on December 17, 2012 at 9:49 pm
    I have Davinci Lite 9.0.4 installed on a Mac Pro, where the Cmd-Shift-C shortcut doesn’t work
    I have Davinci Lite 9.0.4 installed on a Retina Macbook Pro, where the Cmd-Shift-C shortcut works.
    This allows me to quickly show the mask to the DOP, and then immediately turn it off. Without this, it’s much slower…
    Also would it be possible to use the Davinci 8 shortcuts? For example disable all grades with the arrows are faster for me, than finding Alt-D..
    Thanks.
    Laco Gaal replied 13 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Andi Winter
    December 18, 2012 at 12:06 pm
    same on my machine. since 9.0.4 the shortcut seems to be broken or changed.
    weird that it seems to work on your macbookpro.
    andy
  • Laco Gaal
    December 18, 2012 at 12:18 pm
    Sorry…on the retina macbook i have the 9.0.3 installed!
    So it seems to be a bug in the 9.0.4 release.
  • Andi Winter
    December 18, 2012 at 12:51 pm
    i would guess it is not a bug, just a change of a shortcut. you can map it yourself again
    with osx tools (system preferences -> shortcut)
  • Laco Gaal
    December 18, 2012 at 12:58 pm
    You can’t because osx only lets you map a shortcut to one menu item. The Cmd-Shift-C shortcut lets you cycle between the options
  • Andi Winter
    December 18, 2012 at 2:33 pm
    ok. one point for you 🙂
    right, so is it a new shortcut or really a bug? can someone from davinci chime in?
    andy
  • Rohit Singhal
    December 19, 2012 at 2:57 am
    The Window outline shortcut has been changed to option-H. You can switch to Resolve 8 shortcuts by going to Config->Editing.
    Please find the updated shortcuts list here
    https://www.blackmagicdesign.com/support/detail/supportnotes/supportnote?sid=3948&pid=4446&snid=11915&isSDK=false&os=mac
  • Laco Gaal
    December 20, 2012 at 10:43 am
    Thanks Rohit,
    missed the updated list! Hope to get used to it in a few weeks;)
    Thanks again
