Activity Forums Apple Final Cut Pro Legacy Window Layouts
  • Posted by Steve Cohen on April 24, 2009 at 6:34 pm
    I have a custom Window Layouts setup and then some other people stored their Layouts.
    Mine used to be a hot key of Control Shit 6 or something like that.
    Now the saved layouts don’t even show up I have to go to Load Window Layout and then I can call it up.
    There are 2 listings for Custom Layout, but they are grayed out.
    Any ideas on why they are not showing up?
    Thanks.
    Steve Cohen
    Senior Editor
    O2 Media Inc.
    Steve Cohen replied 17 years, 4 months ago 2 Members · 4 Replies
  • Victor Perez
    April 24, 2009 at 6:51 pm
    What version of FCP are you using? I am on 6.0.5 and I am only able to have 5 window layouts with shortcuts of Control/Shift 6, 7, 8, 9 & 0. Any additional window layouts saved after those numbers are filled up are pushed down the line and not accessible thru those shortcuts. Looks like Chaz & Hezys pushed your layouts off the shortcut list.
    hope that helps,
    Victor
  • Steve Cohen
    April 24, 2009 at 8:44 pm
    Sorry forgot to mention that.
    I’m 5.0.6 also and 4 of my 5 workstations don’t show those Control/Shift 6, 7, 8, 9 & 0.
    I only see.
    My 5th station shows…
    2 of my systems are Intel Octocore and 3 or them are Power PC quad core, all of them have 8GB of Ram.
    Interestingly the 1 system that shows the layouts is an Intel, but my system is the other Intel and it has the problem.
    [Victor Perez] “Looks like Chaz & Hezys pushed your layouts off the shortcut list.”
    No mine is not pushed out on that system it is Control/Shift 9, but there are no shortcuts listed on the other systems.?
    Thanks again.
    Steve Cohen
    Senior Editor
    O2 Media Inc.
  • Victor Perez
    April 24, 2009 at 9:46 pm
    In order to use the 2 Custom Layouts you need to save a specific window layout to them.
    In order to do that you need to first hold down OPTION then go to WINDOW / ARRANGE and you will see the 2 options now selectable. This will allow you to set one of the 2 main options.
    good luck
    Victor
  • Steve Cohen
    April 24, 2009 at 11:53 pm
    That is great and I will set it up on Monday, but I’m still confused as to what happened to the other shortcuts.
    Any answers from anyone would be appreciated.
    Steve Cohen
    Senior Editor
    O2 Media Inc.
