Window Burn removal
Posted by Heather Mahoney on October 13, 2010 at 4:33 pmI’m trying to remove window burn timecode from an old film. I just downloaded the trial version of BCC. I need to figure out the best way to remove the TC. Thanks for your help.
Heather Mahoney replied 15 years, 10 months ago 3 Members · 3 Replies -
Peter Mcauley
October 13, 2010 at 6:55 pmHi Heather,
BCC does not really have a filter that will remove the timecode burn from the video clip that you are working with. There is a filter in the package called BCC PixelFixer but that was designed for repairing much smaller groups of pixels than you are dealing with. There is also a filter called BCc Wire Remover which might help but it was really designed for wire / rig removal and not really for removing timecode burn. Having said that, the Wire Remover filter might be your best shot as solving this problem with a BCC filter.
Other than that, there are a couple of other options available:
• you can obscure the timecode with BCC Mosaic or BCC Pyramid Blur
• you can resize the video to effectively crop out the portion with the timecodeI hope this helps.
Cheers,
Peter.
Steve Pankow
October 13, 2010 at 7:59 pmWindow burns are a good thing – they keep people from stealing footage.
Heather Mahoney
October 13, 2010 at 8:26 pmIn this situation window burn is not a good thing. This is a film from 1933 that for whatever reason the only version I have to work with has the timecode burned into the lower left of the frame. It cannot be cropped out without losing a lot of the image. I have decided to go into Adobe AE and use the wire removal tool. I was able to remove the time code but there is a slight blurry area that I just have to make look as good as possible. I know there is no way to totally seamlessly remove the unfortunate window burn. Thanks for your help.
