Activity Forums Adobe After Effects Wind tunnel effect
  • Wind tunnel effect
    Posted by Mint Fresh on August 11, 2006 at 10:20 am
    Does anyone have any ideas how i can create a wind tunnel effect in AE7. I need to simulate a Formula 1 car in a wind tunnel – eg smoke blowing over the shape / profile of the car.
    Any help appreciated
    Coverbee replied 20 years, 1 month ago 3 Members · 2 Replies
  • Steve Roberts
    August 11, 2006 at 11:34 am
    I think you need to make a movie of a thin, fast smoke stream (maybe with Trapcode’s Particular) and render it, then import it and copy it to make a bunch of streams, render and import that, then use one of AE’s distorting effects (liquify?) to distort the bunch of streams in the shape of the car.
    That’s one way …
  • Coverbee
    August 11, 2006 at 1:52 pm
    Hi there !
    Maybe try this one…
    Draw a mask with the pen tool to create the path you want the smoke to follow.
    Copy and paste to a new solid.
    Apply the stroke effect to the mask. Effect> Render> Stroke
    App. Settings : Brush size 9
    Brush hardness 60 %
    Spacing 80 %
    Animate the end of the stroke
    Add some Fast blur to it Blurrines 10 for only the horizontal pixels
    Add a new solid to the comp
    Add some Fractal noise , animate the evolution, let’s say 10 evolutions.
    Precompose this layer.
    Go back to the stroke layer.
    Add a displacement map. Set the fractalnoise comp to be the Displacement map layer. Use Luminance
    Horizontal displ. 8
    Vertical Displ. 1
    Adjust the mask (the smoke trail) to your liking.
    This might need some more adjustments and experimentation but I hope it will help you getting started.
    Best Regards
