Wind noise on audio channel
Posted by Gary Badgley on July 15, 2013 at 1:59 amHowdy, I have some wind noise on one of the audio channels that I would like to delete. Just the wind, not the whole channel. How do I do this? Thanks in advance for the help.
gary
Stephen Mann replied 13 years, 2 months ago 3 Members · 9 Replies -
Stephen Mann
July 15, 2013 at 2:43 amRight click on the event and select left only or right only.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Gary Badgley
July 15, 2013 at 5:03 amHi, but I don’t want to remove the whole channel. I just want to be able to edit it. I know where the wind noise is, and I want to be able to remove just these sections where it is.
thanks.
Stephen Mann
July 15, 2013 at 6:20 amDuplicate the track, make one the left only and the other the right only, then edit the offending event like you would any other event. Maybe turn on the volume envelope and duck the level where the wind noise appears.
Steve Mann
Gary Badgley
July 15, 2013 at 9:03 pmSorry, for being such a dumb puck here, but when I do the audio duck on the left channel, and then try to combine both channels then the audio envelope drops across both channels so I get no sound out of either channel where the audio envelope is established.
Gary Badgley
July 15, 2013 at 9:08 pmOkay, I think I have it. I have to duplicate the track first, then apply left channel, do the audio duck on the duplicated track and then marry up the two.
Michael Gibrall
July 15, 2013 at 9:34 pmAnother alternative, and free but potentially risky to audio quality, is to use software called Audacity.
There is a way to completely eliminate the wind noise by using the software to eliminate the noise you specify throughtout the audio track.
It can eliminate wind, a car driving by, humming in the background, etc.
Only problem is it CAN also affect dialogue in your audio track. It can take away from the quality of it, as well as if overdone, make audio sound digitized. You’d have to play with the settings.
Here’s an instructional video on how to use Audacity to do just that.
https://www.youtube.com/watch?v=mlKX6p85R2M
Do a search online for AUDACITY to find the download.
May not be what you want, though.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Gary Badgley
July 15, 2013 at 10:35 pmYes, I stumbled across this software when I was trying to figure out how to eliminate the wind. There is an example of its use on Youtube, and I had decided to follow up on the software. So, thanks very much. I will take a hard look at it.
Stephen Mann
July 16, 2013 at 3:41 am“and then marry up the two.”
Completely unnecessary. Just leave it as two tracks.
Steve Mann
http://www.mmdv.com
