Activity Forums Adobe Premiere Pro Wind Noise In Audio
  • Wind Noise In Audio
    Posted by Cliff Elliott on March 26, 2006 at 11:34 am
    Hi all, just recently upgraded to Prem2 and looking for advise on which part or comination of the audio effects etc I need to use to remove some unwanted wind noise in some scenes from a video I recorded using a wireless lapel mic.
    Any help would be appreciated.
    Regards, Cliff Elliott
    Cliff Elliott replied 20 years, 5 months ago 2 Members · 2 Replies
  • Ebarfield
    March 28, 2006 at 6:01 pm
    know this is not the answer you want, but if you have audition (1.5 or 2.0), export the audio to a .wav file, then use the hiss removal component of their noise reduction filters (forget the precise name of the filter at the moment). This would probably remove most, if not all, of the wind noise. Not at my system now, and cannot remember if PP has hiss removal specifically. I have never used PP’s noise reduction effects.
    egb
    “deja vu all over again” — Yogi Berra
  • Cliff Elliott
    March 30, 2006 at 9:51 am
    Thank you for your input I don’t have audition but I do have the original cool edit and will try it out.
    Again thanks
    Regards Cliff Elliott
