Activity Forums VEGAS Pro wind noise
  • wind noise
    Posted by Odd Magne nilsen on July 26, 2008 at 8:04 am
    I got some videoclips with a terrible wind noise. Is there a way in VP8 to reduce the problem? I should like to keep as much as possible of the speaking.
    odd magne
    Odd Magne nilsen replied 18 years, 1 month ago 2 Members · 2 Replies
  • John Rofrano
    July 26, 2008 at 2:28 pm
    Wind is mostly a low rumble so you want to EQ out the low end. Open the Track FX on the audio track and select the Track EQ that is already added for you. The first point is already set for Low Shelf, which is what you want. Set the Frequency (Hz) to 300 and the Gain (dB) to –Inf (all the way to the left). Now listen to a loop of your audio and adjust the frequency to filter more or less of the wind. The audio may sound thinner but that’s the trade-off.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Odd Magne nilsen
    July 27, 2008 at 8:23 am
    Thanks a lot, made a great improvement!
    odd magne
