Activity › Forums › Maxon Cinema 4D › Wind + hair: not rendering?
  • Wind + hair: not rendering?
    Posted by Devon Ford on August 18, 2009 at 3:57 pm
    I have created a palm tree using the hair module (constructed each frond using feather object – then used “Generate” option to make polygons so they would cast realistic shadows.) I’ve added a wind object and tweaked the settings so the frond leaves are lightly blowing. When I play the sequence in the viewport, the leaves appear to animate fine, but when I render they are stiff as steel… why is this? Did I miss something I need to turn on?
    Adam Trachtenberg replied 17 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 18, 2009 at 5:29 pm
    That is strange. Have you tried adding a Hair Cache tag?
