Activity Forums Maxon Cinema 4D wind blowing polygons off object
  • wind blowing polygons off object
    Posted by Kevin Welchman on August 11, 2016 at 7:06 pm
    Hey so I need to make a mesh blow in the wind, ploygon by polygon. Then, I need it to orbit around where the figure used to be. Ive tried using x particles 2.0, but I can figure out how to attach the polygons to the particles. Ideally, I would initiate this movement with a plain effector so I could control which parts start to blow in wind.
    Something similar to this: https://vimeo.com/96330045
    I have x particles 2.0 so I cant follow that tutorial (theres no fragmenter in 2.0) but I want this effect
    Im really stressing out about this so any help would be appreciated!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Kevin Welchman replied 10 years, 1 month ago 2 Members · 2 Replies
  • Brian Jones
    August 11, 2016 at 10:08 pm
    thinking particles has the pFragment node which works like that but without the ability to use a falloff. A search for ‘c4d pfragment’ brings up some potentially useful tutorials.
  • Kevin Welchman
    August 11, 2016 at 10:19 pm
    I can’t tell you how happy this makes me. You. Are. The. MAN!
