Activity Forums VEGAS Pro Win7 64bit MP3 Frustration
  • Win7 64bit MP3 Frustration
    Posted by Randall Clarke on December 28, 2010 at 4:14 pm
    With the fraunhofer codec I was able to get higher mp3 encode rates win xp64. With win 7, it didn’t work. I finally found the 64bit lame codec and it appears as a render option. However, the render crashes.
    Just trying to render old hi8 vid to xvid with mp3 audio. Yes, I can just use pcm and yes I can render separately and join in virtual dub but this should work !!! Right now it is limited to 56K and kinda dissapointed coming from Vegas 8…
    thanks..
    John Rofrano replied 15 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    December 28, 2010 at 8:00 pm
    I’m not sure why you are messing with any MP3 codecs at all. Vegas has MP3 support built-in. Now that you’ve installed your own codecs, there’s no telling what damage they may have done. I would uninstall them and re-install Vegas.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Randall Clarke
    December 29, 2010 at 3:26 pm
    Hi
    appreciate your input but sorry I don’t really agree with it. There has never been any good support for this with Vegas – only work arounds and it makes no sense because you can encode MP3 at higher bit rates as an mp3 file, but then when you want to put it into the avi container it doesn’t work ?????
    If you can recommend a codec that will work with divx players that is not as large as pcm then I’m all ears. Reinstalling will do nothing, and installing FFDSHOW has never effected my systems over the years..
    This problem is definetly exclusive to Vegas. I did get high bit mp3 working with the fraunhofer codec and xp64 bit but doing extensive reading it doesn’t look promising in win7
    spent a lot of money on a new quad core, win 7 and vegas 10..hoping it would actually work – mp3 is not some esoteric codec…it should work…looks like a mux in VDub is the extra step work around.,..
    cheers
  • John Rofrano
    December 29, 2010 at 11:09 pm
    [Randall Clarke] “There has never been any good support for this with Vegas – only work arounds and it makes no sense because you can encode MP3 at higher bit rates as an mp3 file, but then when you want to put it into the avi container it doesn’t work ?????”
    Ahh… I missed the part where you are trying to place MP3 in an AVI container. (sorry)
    ~jr
  • Rob Franks
    December 30, 2010 at 12:22 am
    I’m inclined to agree with John. Not too sure why you’re messing around with MP3. I would go with AC3 (Dolby Digital)… either stereo or 5.1 surround should work. It is legal for xvid
  • Rob Franks
    December 30, 2010 at 12:27 am
    One other note:
    Be careful with Vegas and 3rd party codecs. Vegas always wants to render a “compliant” file. If the 3rd party codec being used does not measure up to EXACT standards, then the chances are it will fail.
  • Randall Clarke
    December 30, 2010 at 3:53 am
    thanks for all the info…Are you saying that AC3 will work with divx players ?
    I will do some reading online as well…
    cheers
  • Randall Clarke
    December 30, 2010 at 5:51 pm
    I just used virtual dub and got the file down from 2gig to 1.4 based on video direct stream copy and audio – process – MP3 @ 48k, 160, stereo…So not to be kurt but messin’ with the mp3 reduces the file size dramatically and assures compatibility with divx/dvd players…
    thanks
  • John Rofrano
    December 30, 2010 at 7:10 pm
    That’s great. So now you have a workflow that works for you. Thanks for reporting back. VirtualDub was a good solution.
    ~jr
