Activity Forums VEGAS Pro Will Vegas Pro 5 capture HDV?
  • Will Vegas Pro 5 capture HDV?
    Posted by Willie Bobo on August 4, 2010 at 1:08 pm
    I have V8 on two PCs so I used V5 on a laptop…will it capture HDV (XHA1) via firewire?
    Randy
    Willie Bobo replied 15 years, 9 months ago 2 Members · 4 Replies
  • John Rofrano
    August 4, 2010 at 2:57 pm
    If I remember correctly, the first version of Vegas to support HDV capture was version 6. You could edit HDV in Vegas 5 but you needed to buy Cineform ConnectHD to capture because Vegas 5 didn’t have an HDV capture utility. (but you’re really testing my memory with this one) 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Willie Bobo
    August 4, 2010 at 3:37 pm
    Thanks very much John. after doing dome more research I wonder what you think about HDV Split.
    Thanks again,
    Randy
  • John Rofrano
    August 4, 2010 at 5:19 pm
    Lots of people use HDVSplit with very good results. I had forgotten about it because I use Cineform NeoScene and have no need for it but HDVSplit is definitely something you should check out.
    ~jr
  • Willie Bobo
    August 4, 2010 at 5:36 pm
    Thanks very much John!
