Activity › Forums › DVD Authoring › Will Using Older DVD Burning Software Affect The Quality Of A Burn?
  • Will Using Older DVD Burning Software Affect The Quality Of A Burn?
    Posted by Jackie Luffy on August 28, 2013 at 11:49 pm
    I had just a quick question, i have Nero 7, and I noticed that it says its from 2007!
    pretty old!
    I was just concerned if I should buy a newer version or if I should just keep this version?
    I assume an up to date version would be better but what about the quality of the burn?
    I so far have had no problem with my burns with Nero 7
    But would burning with a newer version do something more? like maybe make the dvds last longer or something like that? Because if not then I might as well stay with this older version
    Help is appreciated!
    Jeff Pulera replied 13 years, 1 month ago 3 Members · 2 Replies
  • Michael Slowe
    August 29, 2013 at 9:26 am
    There probably wouldn’t be a great difference although I find that the later versions of BitVice (great encoding software) have, not only done the job much faster, but give an even better quality picture. The lasting times of DVD’s vary considerably, depending on how they are kept. Sunlight is not a good idea! I was once told that we shouldn’t depend on a burnt DVD lasting much more than five years, as opposed to the commercially pressed discs. Something to do with the dyes used in the disc.
    Michael Slowe
  • Jeff Pulera
    August 29, 2013 at 2:36 pm
    If you’re concerned about using outdated software, download “ImgBurn” – it is free and up to date. I create .iso files from Adobe Encore and then quickly burn with ImgBurn.
    Jeff Pulera
    Safe Harbor Computers
