Activity › Forums › Apple Final Cut Pro Legacy › Will these editing steps result in a loss of quality when transferred to 35mm film?
  • Will these editing steps result in a loss of quality when transferred to 35mm film?
    Posted by Chris Mastropaolo on January 17, 2008 at 7:51 pm
    Question for creative cow
    I am editing a film shot on 24pa on a dvx100b, being edited on final cut 6.0.2. Most of the film was imported at 23.98, with advanced frame pulldown. Some clips do not import, stating break in cadence/timecode. These clips were imported as 29.97 and once digitized, I tried to pulldown with TOOLS>REMOVE ADVANCE PULLDOWN. Ths still would not work stating once again breaks in timecode/cadence.
    Here
    David Jahns replied 18 years, 8 months ago 3 Members · 2 Replies
  • Paul Escandon
    January 17, 2008 at 9:40 pm
    I can’t understand how the method you’re using to get around the problem clips where the pulldown wasn’t getting removed would result in something that looks good. Taking a 29.97 clip with pulldown and simply exporting it as 23.98 from Final Cut should not remove the pulldown properly and I haven’t to imagine there would be some strange visual inaccuracies in the image. But you’re not noticing any problems with it?
    As far as your first steps with the 24PA footage – yeah as long as you get the pulldown removed you should be able to do a film out from that footage. It’s no HD but I’ve seen films shot with it before.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • David Jahns
    January 17, 2008 at 10:21 pm
    Yes, try to recapture them as individual clips.
    If that doesn’t work, Export the clips at 29.97 individually, then re-import them and use the Tools –> Remove Advanced Pulldown.
    (I don’t think Cinema Tools works for Advanced Pulldown removal, but I could be wrong.)
    If you view your windows at 100%, you should be able to see any pulldown artifacts, and this will also help you detect the cadence inconsistencies. You should see a blended frame once every 5 frames – 00, 05, 10, 15 or 02, 07, 12, 17, etc…
    When that blended frame changes from a 00 to a 01 (or whatever), that’s where your cadence break is. Put a marker there and use it to break it into individual clips.
    Tedious, yes – but it should work.
