Activity Forums VEGAS Pro Will there be any audio problem if I will use two clips with different framerate?
  • Will there be any audio problem if I will use two clips with different framerate?
    Posted by Gennady Gaidukevich on June 10, 2018 at 10:26 pm
    Will there be any audio sync problem if I move two clips with different framerate (let’s say 24fps and 30fps) in one project and render it as one file with 24 or 30 fps? Asking this because had this problem in Adobe Premiere: was making video that included 29fps video and some other videos in that project had different framerate and eventually I ended up with audio sync issues.
    Graham Bernard replied 8 years, 3 months ago 2 Members · 1 Reply
  • Graham Bernard
    June 11, 2018 at 8:55 am
    I’ve worked 23.567p fps + 25i fps rendered to AVI, MP4, MOV, WMV or MXF and also AC3 and MPG2 never has an issue. BUT! Do your own test and see what gives.
    * Grazie
