Activity Forums Apple Final Cut Pro Legacy Will ProRes422 rendering improve an HD DVD?
  • Will ProRes422 rendering improve an HD DVD?
    Posted by Alfred Guzzetti on January 3, 2008 at 5:43 pm
    I’ve been editing a project in HDV on FCP 6, capturing via firewire and editing using the regular HDV codec. Now I’m getting ready to export to Compressor, where I’ll make an mpeg2 file at 19 Mbps and bring this in to DVDSP in order to burn a 30-minute-long HD DVD on a 4.7GB disk. I’ve tried all this and everything works well. My question is this: is it worth while to copy and paste my video into a new FCP sequence where ProRes422 is selected as the rendering codec (this seems to produce better results with some fades) and export to Compressor from there–or is this just a waste of time considering that Compressor will simply create a new mpeg2 file?
    ALFRED GUZZETTI
    Alfred Guzzetti replied 18 years, 8 months ago 5 Members · 6 Replies
  • Uli Plank
    January 3, 2008 at 6:19 pm
    If you could afford to have 25 mbps on the DVD, you’d be able to use your native footage
  • Paul Escandon
    January 3, 2008 at 6:37 pm
    I vote for waste of time.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Walter Biscardi
    January 3, 2008 at 6:39 pm
    Nope, just stick with the HDV codec all the way through.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Alfred Guzzetti
    January 3, 2008 at 8:49 pm
    Many thanks. Unfortunately at 25 Mbps I can’t fit 30 minutes onto the 4.7GB DVD. In cases where I’ve had a shorter tape, I’ve put the file onto the HD DVD in its native form, as you suggest, with very good results. But in a test, I wasn’t able to see any obvious difference between the native 25Mbps and the same material compressed further to 19Mbps.
    Alfred Guzzetti
    Mac Pro Quad 2.66GHz 4GB RAM
    Intensity Pro card
    OS 10.4.9
    FCP 6.0
  • Sean Oneil
    January 3, 2008 at 9:03 pm
    Have you considered using a Dual Layer DVD?
  • Alfred Guzzetti
    January 3, 2008 at 10:23 pm
    Thanks for the suggestion. My experience is that dual-layer DVDs sometimes produce a hesitation on playback when the player switches layers. Our project is a gallery installation involving 5 HD DVDs playing back in synchronization. Exact synchronization of the players currently on the market evidently isn’t possible; so we’ve had to settle for starting the machines together using an infrared relay. We find that holds to within a fraction of a second even after several hours of repeating. I don’t want to introduce more possibilities of synchronization or playback error than I have to.
    ALFRED
    Alfred Guzzetti
    Intensity Pro card
    OS 10.4.9
    FCP 6.0
