Activity Forums Adobe Premiere Pro Will PPro CS4.1 install on 1280×800 laptop?
  • Will PPro CS4.1 install on 1280×800 laptop?
    Posted by Jack Kelly on June 19, 2009 at 7:39 pm
    Hi there,
    I’m about to buy a new laptop and my favorite laptops have a resolution of 1280×800. I’d like to run PPro CS4.1 on my new laptop (not as my primary edit system but as a portable edit system). But the PPro “minimum requirements” specify a res of 1280×900.
    Has anyone successfully installed PPro on a laptop with a screen with a res of only 1280×800??? Will it literally REFUSE to install if it detects a screen res of 1280×800???
    Many thanks,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
    Jack-Kelly.com – my homepage
    Jack Kelly replied 17 years, 2 months ago 3 Members · 3 Replies
  • Tim Robinson
    June 19, 2009 at 8:25 pm
    CS3 used to refuse if it didn’t match. Is there anyway to turn it up, even if unviewable to install?
    Tim Robinson
    tim@erobinsons.com
    Pride-Mobility-Products
    Corporate Video Editor
  • Tim Kolb
    June 20, 2009 at 1:14 am
    Hi Jack,
    My primary concern would be whether or not the machine has the juice for CS4, even if you could skirt the minimum display requirement.
    I stopped installing Adobe anything on my more portable email laptops as it just doesn’t really run.
    I use Vegas on my small machine…very scalable.
    TimK,
    Director, Consultant
    Kolb Productions,
  • Jack Kelly
    June 22, 2009 at 1:13 pm
    Hey guys,
    Thanks loads for the replies!
    One quick thought… I have recently installed Illutrator CS3 on a netbook with a screen res of only 1024×600. The installer initially refused to install because the laptop’s screen has such a low native resolution. So I plugged the laptop into a larger screen and re-ran the install. The software installed fine while the netbook was connected to the large screen and Illustrator will now run on the netbook with a 1024×600 resolution (which would be pretty painful for doing any serious work but it’s fine for reviewing material whilst on the road etc).
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
