Activity › Forums › Adobe Premiere Pro › Will PPRO CC 2014.1 run better then PPRO CS5 on a weak PC?
Posted by Yair Bartal on August 18, 2015 at 11:07 amIntel Core2 Duo
4 GB ramAnn Bens replied 11 years, 1 month ago 3 Members · 5 Replies -
David Roth weiss
August 18, 2015 at 5:52 pmIf I were you I would check the Adobe minimum requirements page, or simply install the 30-day free demo and try it out. If I had to guess, I’d say it will run on your old computer, but not well. You could add some newer components to improve performance, but you’d be better served by buying a newer and more modern computer.
David Roth Weiss
Director/Editor/Colorist
David Weiss ProductionsDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Yair Bartal
August 18, 2015 at 6:16 pmThanks David.
I’ve already checked Adobe minimum requirements page.
Both versions require the same minimum CPU, however CS5 requires 2 GB ram whereas CC 2014.1 requires 4 GB ram.
So on the face of it, CS5 will run better with 4 GB ram.
On the other hand CC 2014.1 may have more efficient algorithms and certainly more and easier options.
I thought someone has relevant experience. -
David Roth weiss
August 18, 2015 at 8:00 pmI seriously doubt you’ll find any answers here coming from users experienced with that computer, cuz you’re unlikely to find many professionals using the latest version of CC with the bare minimum in terms of required hardware, and according to Adobe, your old Core Duo machine is the absolute minimum required.
David Roth Weiss
Ann Bens
August 18, 2015 at 8:12 pmIt will probably run but you wont able to edit beyond SD DV footage.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
