Activity Forums Adobe Premiere Pro will pay 100.00 cash for info
  • will pay 100.00 cash for info
    Posted by David Masterson on January 20, 2008 at 11:57 pm
    NEED HELP –
    I have a problem with Adobe Premier. When I do a new project, build a timeline, import my narration and music, add all my transistions….then close the file, re open…all audio is gone…the boxs they are suppose to be in is there, but its like all audio lines have been muted.
    two projects down the tubes now,,,,,must find problem and fix…workflow has stopped
    please help
    Will pay someone 100.00 to help me figure this out asap
    Dave Masterson
    936 591 2971
    Jean-paul Moodie replied 18 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Vince Becquiot
    January 21, 2008 at 2:21 am
    I’ll do it for a thousand 🙂
    Have you tried deleting all the peak files? These should be in your “project name” > Media cache (all .pk files). This can happen when complex projects run out of memory, thus get corrupt. If that’s not the issue let us know and we eill go down the line in possible issues.
    Premiere will index the files again, if it doesn’t, those weren’t the right ones.
    Vince
  • David Masterson
    January 21, 2008 at 3:41 pm
    thanks for the advice. cant swing a grand but a hundred bucks I have…lol….. I have tried that to no avail. Is it possible that you could call me and we can discuss these issues with me at the system. It might be that I am not clearing things out right. I have 4 hard drives and I am moving things around all the time
    I will be back in my office after 3:00 today( Texas time) if you can call me.
    Thanks for your help
    RD
    936 591 2971
  • Vince Becquiot
    January 21, 2008 at 10:05 pm
    I’m actually on a production and can’t keep my phone around because of interferences. But you can post here, I’ll be online most of the day, just doing inteviews every couple of hours 🙂
    Anyway, WIFI is all I have.
    So all your files are audio AND video, or is the audio separate?
    After you deleted the peak files, did Premiere generate new ones? Did it show a progress bar at the lower right bottom ?
    Vince
  • David Masterson
    January 22, 2008 at 4:30 pm
    okay this is what happens…I will build a project on E,D or F drive, I have a 500GB ext hard drive for storage.
    after I build the timeline, drop in narration and music, do all my transistions, bascly finish it, I close it out. The next day when I return to check over the project, tweek here and there…the audio is gone. On the timeline you see all the blocks audio and video, but all the audio boxs are like…empty. I have checked everything I know to check. Then last week I had a project that when I opened it the next day all my video transistions had disaperaed( sorry, my spelling sux)
    I am still baffeled and, reluctent to do any new work unless I turn key it in one seting
    Yes, I have also tried at the end, making a copy, placing it as a new project on another HD…sometimes this works
    signed …..help me!
    RD
  • Vince Becquiot
    January 22, 2008 at 10:18 pm
    That’s certainely not something you should see happen TWICE. I have yet to see it happen once.
    So, again, are the video files and audio files separate in your project, or are these simply files as you would get them off the camera? Anyway to post a screen cap of your timeline?
    If they are the all in one audio and video type, then I’ll have to go back to that .pk file issue, since otherwise your video files wouldn’t work either. Did it ver ask you to relink any files before that happened?
    Vince
  • Lance Bauerfeind
    January 23, 2008 at 3:07 am
    I’ve had this a couple of times.
    Try unlinking then relinking your clips.
    Worked for me but don’t know why it happens.
    Lance
  • Jean-paul Moodie
    January 24, 2008 at 10:07 pm
    My bet is on the audio files not being linked, its also prob not in the project folder, but on a diff drive.. Try putting all assets on the same drive – re-link after if necessary.
    Jean-Paul
    Focus Motion Media
    Cape Town, SA
