Activity Forums Adobe After Effects Expressions Will Pay $100 for Aid Animating Tires on Element 3D car.
  • Satyen Guru
    January 9, 2014 at 10:29 am
    [Jason Jenkins] “…expressions that will rotate tires to match chassis movement!”
    What you are looking for might not be this simple, but….
    ‘Rotating the tires according to the chassis movement (on just x-axis)’ is what you are looking for? Then you can simply pick whip the tire controller’s Rotation to the chassis controller’s Position X-value.
  • Jason Jantzen
    January 9, 2014 at 5:08 pm
    Ha, I used to work for Defensive Driving. Just ask J.C. about Jason Jantzen 🙂 I can help with that if you want to send the project file over. My email is jasonpj3ATgmailDOTcom
    Jason Jantzen
    vimeo.com/jasonj
  • Jason Jenkins
    January 9, 2014 at 5:33 pm
    I just sent the project file to you, Jason!
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
    Check out my Mormon.org profile.
  • Jason Jenkins
    January 9, 2014 at 5:34 pm
    [Satyen Guru] “Then you can simply pick whip the tire controller’s Rotation to the chassis controller’s Position X-value.”
    Unfortunately, this falls apart in 3D. The car is animated on the X & Z plane.
    Jason Jenkins
    Flowmotion Media
  • Jason Jenkins
    January 10, 2014 at 3:59 am
    Thanks to the talents of Jason Jantzen and Dan Ebberts, I’m back on track!
    Jason Jenkins
    Flowmotion Media
