Activity Forums Creative Community Conversations Will my Mac Pro Tower handle FCPX?
  • Will my Mac Pro Tower handle FCPX?
    Posted by Ned Miller on December 8, 2012 at 11:04 pm
    I would like to migrate to FCPX from my present FCP6 on OS 10.5.8 and will probably get a 27″ iMac in the spring. As of now I need to limp along with my tower which is probably five years old. Here’s the specs:
    Model Name: Mac Pro
    Model Identifier: MacPro3,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.8 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 12 MB
    Memory: 6 GB
    Bus Speed: 1.6 GHz
    Boot ROM Version: MP31.006C.B05
    SMC Version (system): 1.25f4
    I don’t know if I can improve the speed or memory, can I? Will this work with FCPX and/or do I need to upgrade to a newer OS?
    Many thanks for your advice!
    Ned Miller
    Chicago Videographer
    http://www.nedmiller.com
    www,bizvideo.com
    John Davidson replied 13 years, 9 months ago 11 Members · 30 Replies
  • 30 Replies
  • Steve Connor
    December 8, 2012 at 11:28 pm
    [Ned Miller] “As of now I need to limp along with my tower which is probably five years old”
    I have the same Mac with 16GB RAM and an ATI Radeon 4870 card, it doesn’t ‘limp along” it runs FCPX very well. Add some RAM and make sure you have a good graphics card and you’ll be fine.
    Steve Connor
    ‘It’s just my opinion, with an occasional fact thrown in for good measure”
  • Ned Miller
    December 8, 2012 at 11:34 pm
    Hi Steve,
    Should i bring it into he store and have them do it or is it a DIY project?
    Ned Miller
    www,bizvideo.com
  • Mark Dobson
    December 9, 2012 at 8:42 am
    [Ned Miller] “Should i bring it into he store and have them do it or is it a DIY project?
    Unless you are very hamfisted I’d say you could add more memory and a new Graphic card yourself ( that’s if you need one )
    On the minimum system requirements section on the Apple FCPX Technical Specifications page they recommend an openCL-capable graphics card or Intel HD Graphics 3000 or later.
    And they only recommend 6GB of RAM!
    I’ve got a similar Mac Pro and have now installed 22GB of RAM but I’m not that sure how much it helps me.
    There are loads of instructional documents and tutorials available on the net and it’s good to get to know your mac.
    However if you are only planning to use it for a couple of months your will be sinking cash into a soon to be redundant system.
    What I would do is install FCPX on your Mac Pro as it is at the moment and see how you get on.
  • Tony Brittan
    December 9, 2012 at 2:28 pm
    Check out OWC @ macsales.com and you’ll find GREAT prices for your upgrades and EASY instructional videos for each. On the Mac Pro its very easy to do both things.
  • Ned Miller
    December 9, 2012 at 3:42 pm
    Thanks for the advice. It says I need to upgrade my OS so I must wait until I am done with some of the editing projects I am in the middle of. After that I can download the trial version.
    If I can get this tower to run X fairly well then I don’t need to buy the 27″ iMac. I presently have two large Cinema Display monitors so it would be great if I don’t need a new computer.
    Ned Miller
    www,bizvideo.com
  • Ned Miller
    December 9, 2012 at 3:54 pm
    Post Script: I just figured out I would need a new card. Seems around the $700 range. That plus a new OS I think I might as well buy the iMac, ugh!
    Need a favor. Could you please look at these specs from my tower and tell me if this card is capable? I’m not that technical, basically a DP who produces now and then. Apple says on their website: OpenCL-capable graphics card or Intel HD Graphics 3000 or later. What is CL?
    Here’s what I have on my Mac:
    ATI Radeon HD 2600 XT:
    Chipset Model: ATI Radeon HD 2600
    Type: Display
    Bus: PCIe
    Slot: Slot-1
    PCIe Lane Width: x16
    VRAM (Total): 256 MB
    Vendor: ATI (0x1002)
    Device ID: 0x9588
    Revision ID: 0x0000
    ROM Revision: 113-B1480A-252
    EFI Driver Version: 01.00.252
    Displays:
    Cinema:
    Resolution: 1680 x 1050
    Depth: 32-Bit Color
    Core Image: Hardware Accelerated
    Mirror: Off
    Online: Yes
    Quartz Extreme: Supported
    Rotation: Supported
    Cinema HD:
    Resolution: 1920 x 1200
    Depth: 32-Bit Color
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Rotation: Supported
    Memory Slots:
    ECC: Enabled
    DIMM Riser B/DIMM 1:
    Type: DDR2 FB-DIMM
    Speed: 800 MHz
    Status: OK
    Manufacturer: 0x0000
    Part Number: 0x000000463732353642363145353830304600
    Serial Number: 0x00000000
    DIMM Riser B/DIMM 2:
    Type: DDR2 FB-DIMM
    Speed: 800 MHz
    Status: OK
    DIMM Riser A/DIMM 1:
    Type: DDR2 FB-DIMM
    Speed: 800 MHz
    Status: OK
    Manufacturer: 0x830B
    Part Number: 0x4E543147543732553850423942442D324320
    Serial Number: 0x35313441
    DIMM Riser A/DIMM 2:
    Type: DDR2 FB-DIMM
    Speed: 800 MHz
    Status: OK
    Serial Number: 0x85303441
    DIMM Riser B/DIMM 3:
    Type: Empty
    Speed: Empty
    Status: Empty
    Manufacturer: Empty
    Part Number: Empty
    Serial Number: Empty
    DIMM Riser B/DIMM 4:
    Type: Empty
    Speed: Empty
    Status: Empty
    Manufacturer: Empty
    Part Number: Empty
    DIMM Riser A/DIMM 3:
    Type: Empty
    Speed: Empty
    Status: Empty
    Manufacturer: Empty
    Part Number: Empty
    DIMM Riser A/DIMM 4:
    Type: Empty
    Speed: Empty
    Status: Empty
    Manufacturer: Empty
    Part Number: Empty
    Ned Miller
    www,bizvideo.com
  • Bob Zelin
    December 9, 2012 at 5:20 pm
    what crazy advice you are getting.
    Leave your old hard drive alone.
    Put in a new hard drive in your Mac Pro (you have 4 slots in that computer). Build an OS X Snow Leopard boot drive ($29 at the Apple store, and I am sure you can find this on ebay), and then upgrade with the APP store to OS X Mountain Lion (OS X 10.8.2). If you can’t figure out how to do this, then find a 12 year old, because they all know how to use the APP store.
    Once you are running OS X 10.8.2, go back to the App store and download FCP X. That’s it. Now you can boot off of your existing hard drive, and continue to work, and when you want to play around, just go to System Preferences>Startup Disk, select your new boot drive with 10.8.2 on it and FCP-X, and play all you want.
    Bob Zelin
  • David Chai
    December 9, 2012 at 5:32 pm
    Your 2600xt graphics card is not supported, so you’ll need to upgrade that to a better one. The mac 5770 works fine, or if you are more adventurous, you can get a PC nvidia GTX 570 or 670. Just install mountain lion first.
    David Chai
    Writer . Director
    http://www.davidchai.com
    dc@davidchai.com
    212 363 0159
  • David Eaks
    December 9, 2012 at 6:40 pm
    I have the same Mac as well but with 16gb of OWC RAM, a Radeon 5770 and SSD boot drive. FCPX runs great.
    I’m with Bob, leave your current drive alone and get a new one for playing with this new stuff. For your new Mountain Lion and FCPX drive, I recommend a 128gb Crucial M4 SSD, for around $100 (don’t forget the 2.5″ to 3.5″ adapter) it’s well worth it.
  • Dave Jenkins
    December 9, 2012 at 6:44 pm
    I installed FCP X on a 2006 iMac and it works! (Not great, but it works) It comes up with a message and says the graphics card is not supported. I hit the button message disappears and Final Cut X launches and works. I agree with Bob, put in another hard drive and see what you think about Final Cut X before you spend any money. Play with it, if you like it then think about upgrading your tower or getting a new iMac.
    Dajen Productions, Santa Barbara, CA
    MacPro Two 2.66GHz Quad Core – AJA Kona LHe
    FCS 3 OS X 10.7.4
    FCP X, Adobe CS6, Logic Pro, Squeeze, Filemaker
Page 1 of 3
