Activity Forums AJA Video Systems will kona2 do 1080p?
  • Gary Adcock
    August 31, 2009 at 4:40 pm
    [mark pigott] “From the original spec sheet it says that the kona2 will only do 1080i;
    will it do 1080p with some type of driver update?
    Ok
    couple of things
    that card is not longer being made
    it was always capable of handling P/ PsF correctly depending on your format.
    Yes the current driver build
    https://www.aja.com/ajashare/AJA_Kona2_6.0.3.zip
    AJA Driver Compatibility as of KONA Version 6.0.3 is as follows:
    FCP 6.0.x – Kona Driver version 6.0.3 (Leopard and Tiger OS compatible version)
    FCP 6.0.x – Kona Driver version 5.0 through 5.1 NDD (Leopard and Tiger OS-
    compatible versions)
    FCP 6.0.x – Kona Driver version 4.0 (Tiger OS compatible version)
    is good thru FCP 6
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
