Activity › Forums › Adobe Premiere Pro › Will I get dropped frames if I re-encode a HAP 60fps file?
  • Will I get dropped frames if I re-encode a HAP 60fps file?
    Posted by Kit Carson on September 20, 2019 at 2:44 am
    I have a HAP video I have created and I have to add another 1 minute of footage to the end of the file, but I dont have the original source clips.
    If I drop the HAP 60fps file into something like adobe premiere, then add the additional material to the end then re-render it, will I retain my full 60fps, or will the software drop some of the frames?
    I ask because there is some very fast stroboscopic material in the content that if any frames get dropped will be quite evident.
    Thanks in advance.
    Shane Ross replied 7 years ago 2 Members · 1 Reply
  • Shane Ross
    September 20, 2019 at 6:10 am
    It won’t drop any frames unless you tell it too. If you take a 60fps file, and encode to another 60fps file, all 60fps will be there.
    Shane
    Little Frog Post
