Activity › Forums › Blackmagic Design › Will i be able to monitor HDV out of a HD PRO card ?
Posted by Nick B on April 21, 2005 at 6:03 pmNow that FCP5 supports hdv will i get a real time monitor o/p from a HD pro decklink card ?
Thanks.
Luke Maslen replied 21 years, 5 months ago 4 Members · 4 Replies -
Luke Maslen
April 22, 2005 at 12:59 amHi Nick,
Absolutely. You will need FCP5 and the DeckLink v5 drivers to support HDV, and then you will have HDV real-time monitoring from all DeckLink HD series cards.
Regards,
Luke Maslen
Blackmagic Design -
Brian
April 22, 2005 at 4:14 amWill we be able to edit HDV material in FCP5 with downconverted output through a DeckLInk card? Will this be smooth or will it be too demanding for current Macs?
Luke Maslen
April 22, 2005 at 7:49 amHi Brian,
I’m not sure if software downconversion of HDV is possible but we’ll definitely check it out. The DeckLink HD Pro 4:4:4 card can perform hardware downconversion of pretty much anything including JPEG so I expect it will work with HDV. I’m not sure that anyone has tested this but we will do so before the drivers ship.
Regards,
Luke Maslen
Blackmagic Design
