Activity Forums Panasonic Cameras Will HPX-170 output SD-SDI?
  • Will HPX-170 output SD-SDI?
    Posted by Craig Bernstein on June 6, 2009 at 12:47 am
    I need to hook an HPX-170 up to an SD-SDI only piece of gear (Newtek Tricaster Broadcast).
    Does anyone happen to know if the BNC [SDI] OUTPUT on the HPX-170 is switchable between HD-SDI and SD-SDI?
    Thanks in advance.
    Jan Crittenden livingston replied 17 years, 3 months ago 3 Members · 2 Replies
  • Steve Eisen
    June 6, 2009 at 1:35 am
    It will automatically detect it. You do have to make sure that the setting is set for SDI out.
    AV IN/OUT Setup: SDI=On
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Jan Crittenden livingston
    June 7, 2009 at 1:13 pm
    And there is a menu item where you have to choose 480i as your output if you are looking to do a downconvert and send to a SD monitor.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HVX200, DVX100
    Panasonic Broadcast & TV Systems
