Activity Forums Apple Final Cut Pro Legacy Will HDV and DV work on the same Timeline?
  • Will HDV and DV work on the same Timeline?
    Posted by Fletch on February 1, 2006 at 3:16 pm
    HI
    I’m about to online a film on FCP5, which is mostly HDV (PAL), but also has some DV-PAL footage. Can I put these on the same timeline?
    Also, as HDV is Upper Field, and PAL is Lower Field, will this cause a problem?
    Thanks for your time!!!
    Fletch
    Jeff Carpenter replied 20 years, 7 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    February 1, 2006 at 3:43 pm
    Combining any two formats in Final Cut will require you to render whichever format is different from the project-settings.
    You’re much better off converting the files that are different to the same format BEFORE you import them into your project. It takes some time up front but you’ll save a ton of time while editing.
