Activity Forums Apple Final Cut Pro Legacy will final cut 5.1.4 work with a Panasonic AG-HMC150
  • will final cut 5.1.4 work with a Panasonic AG-HMC150
    Posted by Mark Howe on January 6, 2011 at 6:14 pm
    Will final cut 5.1.4 work with a Panasonic AG-HMC150, the camera records in AVCHD format. My computer is a Mac g5. Thanks everyone.
    Mark Howe replied 15 years, 8 months ago 3 Members · 4 Replies
  • Shane Ross
    January 6, 2011 at 6:16 pm
    Directly? No. That camera only works with the LOG and TRANSFER option in FCP, so you can convert it to ProRes. FCP 5.1 doesn’t do ProRes, nor does it have LOG AND TRANSFER, it has IMPORT>P2…that was later updated to include other formats.
    If you get third party software, however, like ClipWrap2…you can use that to convert the footage to DVCPRO HD…and that works with FCP 5.1.
    Shane
  • Mark Howe
    January 6, 2011 at 7:22 pm
    Thanks this helps alot!
  • Kent Stipp
    January 6, 2011 at 11:02 pm
    Or you can upgrade your final cut depending on your machine. To upgrade is not so expensive then your good to go..
    Just food for thought 🙂
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
  • Mark Howe
    January 8, 2011 at 2:39 am
    Thanks for the advice, I think I try for the upgrade.
