Activity Forums Apple Final Cut Pro Will FCP X import from my Scratch Disk ?
  • Will FCP X import from my Scratch Disk ?
    Posted by Fredy Schwerdtner on July 15, 2011 at 5:40 pm
    I have a job that I would like to do on both App FCP7 & FCP X at the same time for comparison and to get familiar with the New One. I haven’t installed the X yet but I’m thinking in doing it soon.
    I have already ingest the material from my HDV Camera to FCP7 using the preset HDV -> Prores 422 and the files are on my Raid Scratch Disk.
    The question is: I have to import the files again to work with them in X, right ?
    They are already transcoded to Prores 422 in my Media Folder at the Scratch Disk .
    Will X copy again the files to another folder ??
    PS.: Does anybody knows or has a clue if FCP7 or FCP X are going to work faster and better on Lion ?
    Thanks you all in advance.
    iMac 2.7 GHz Intel 4 Core i5
    16 GB memory
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    6GB 667 MHz DDR2 SDRAM
    OWC RAID 5 with 3TB
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.6.5
    Final Cut Studio “3”
    Craig Seeman replied 15 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Craig Seeman
    July 15, 2011 at 7:14 pm
    You should be able to import the files but in your FCPX Import Preferences, Disable Copy files to Final Cut Events folder so it doesn’t duplicate the media. It will just create aliases instead.
  • Fredy Schwerdtner
    July 15, 2011 at 7:56 pm
    thanks for answering ….
    So, this “copy thing” in preferences is to keep the originals where they are, another HD, Desktop or wherever, to be there as a backup ?
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 3TB
    OS X 10.6.5
  • Noah Kadner
    July 15, 2011 at 8:15 pm
    Copy will automatically make a copy of your ingested media onto your System drive. IF you already have ProRes versions from FCP 7, checking that off will simply link to your original files instead of making a second copy. Which is more what you’d be used to seeing in FCP 7.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and GoPro HD Hero.
  • Craig Seeman
    July 15, 2011 at 8:26 pm
    [Noah Kadner] “Copy will automatically make a copy of your ingested media onto your System drive”
    Actually it will copy to the Drive your Event is on. It doesn’t have to be the System Drive at all.
  • Noah Kadner
    July 15, 2011 at 8:34 pm
    Right- meant by default.
    Noah
  • Fredy Schwerdtner
    July 15, 2011 at 8:41 pm
    Otherwise X would do what I’ve heard here so many times ….”Do not use the system drive as Scratch Disk …”
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 3TB
    OS X 10.6.5
  • Fredy Schwerdtner
    July 15, 2011 at 8:44 pm
    Thanks guys ….
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 3TB
    OS X 10.6.5
  • Craig Seeman
    July 15, 2011 at 8:59 pm
    It’s interesting that FCP legacy would drop things in the Document folder by default and FCPX’s “advancement” is now it defaults to the Movie folder.
    I wonder if it would make more sense if you just got a popup asking where rather than ever defaulting to the system drive. I could see someone getting backed into using the system drive if they have a laptop and “forgot” their external drives but then even that case should be a conscious decision.
