Will extra HDs speed up a project using Vegas Pro 13
Posted by Tom Blizzard on August 3, 2015 at 4:35 pmHi,
I’m new here and using the trial version of Vegas 13. I know from Premiere Pro experience that using 4 hard drives to spread out the work can help with the editing, encoding, rendering and export process. Is that true with Vagas 13? If so, is there a resource available that will show the best way to spread out the project? Thanks TomBob Peterson replied 11 years, 1 month ago 5 Members · 5 Replies -
Danny Hays
August 3, 2015 at 5:53 pmYes, as far as Disc IO and if they are 7200 rpm drives, and if half the videos ore on each drive. Putting a solid state drive in will make way more of a difference though.
Danny Hays
Samples of my Work can be seen here:
https://www.youtube.com/user/ErnestDaniels/videos -
Aaron Star
August 3, 2015 at 7:31 pmThe best way to determine this is using windows Task Manager, or create performance monitor to run in the background while you edit.
Windows Key + R, then perfmon
Click the + icon, and add Logical Disk stats to the graph. Uncheck everything you do not want to see. You are most interested in %Read, %Write, Disk Queue. If you are seeing peaks of 100% on reads during editing, your disk could be holding you back. Disk Queue is another indicator that commands are stacking up and waiting on the disk to deliver.
In Task Manger some of these stats are shown as well, but perfmon allows you to record data of a large period of time.
Often times people are not held back by their disks, since most are editing AVCHD video that is generally only 4MB/s per stream. Most cheapo desktop drives from WD or Seagate can handle delivering a bunch of those streams at once.
Using a tool like Speccy, you can go into your SATA controller and verify that your drive is operating at its max interface speed, and if your SATA controller is operating in NCQ mode. If the drive is not operating at max interface speed, or NCQ, repair or upgrade this.
Normally most peoples complaints of bad editing performance in Vegas, comes from slow or not enough memory, slow CPU that does not support instructions that Vegas takes advantage of, or poor GPU compute abilities.
Tom Blizzard
August 3, 2015 at 9:59 pmThanks Danny and Aaron. This gets me started. I always use 7200 rpm drives, sata and esata and with an i7 processor and 32 gig of ram, I should be okay. I’ve just got to get familiar with the separate processes. I’d rather not have too much coming in and out of the same drive at the same time. I think that is important. If that’s possible.
Tks, Tom B. -
Wayne Waag
August 4, 2015 at 12:06 amThis may be a bit simplistic, but really whats most important is to avoid simultaneously reading and writing to the same drive. Usually, this means that your assets are on one drive (the faster or possibly spread across drives) and you’re rendering to a second drive. An SSD can definitely speed things up, especially if you’re using digital intermediates that take up quite a bit of space and require a lot of “reading”. The drive that you render to is usually not that speed dependent since the actual “writing” is usually the quickest part of the rendering process. Just another opinion.
wwaag
Bob Peterson
August 4, 2015 at 4:00 amYou can certainly put the source files on one drive, and the output file on a separate drive. Of course, Windows, programs, and paging files should not be on either of these drives for fastest throughput. You should probably also look at cpu utilization. Most people here will say that the cpu is the biggest factor in the speed of a render. If the cpu has high utilization, you don’t need to be concerned that disk drives are slowing the render.
