Activity Forums Blackmagic Design Will current BMD drivers work with FCP 5.1.2?
  • Will current BMD drivers work with FCP 5.1.2?
    Posted by Daniel Weber on September 27, 2006 at 3:03 pm
    I am about to download the new FCP 5.1.2 update and wanted to make sure that the current BMD drivers would work before I upgrade my software.
    Dan Weber
    Rob Das replied 19 years, 11 months ago 4 Members · 4 Replies
  • Luke Maslen
    September 28, 2006 at 5:10 am
    Hi Dan,
    Yes, they work fine with Final Cut Pro HD 5.1.2 and in fact I would recommend the update to Final Cut Pro HD 5.1.2. We’ve been testing with all the pre-release versions of Final Cut Pro HD 5.1.2 and so can recommend this version.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Rob Das
    September 28, 2006 at 8:52 am
    I am afraid I was not that lucky, Since the 5.1.2 upgrade I have kernel panics while booting and I had to uninstall the card to be able to work, I have no idea how to downgrade to 5.1.1, so I can’t use my Decklink (HD PCI-X) card for now…
    PowerPC G5 DP2, FCP 5.0.4, Decklink HD, XserveRAID
  • Jo Hermann
    September 29, 2006 at 10:26 am
  • Rob Das
    September 30, 2006 at 8:06 pm
    Turns out the Decklink 5.7 driver was the culprit here, installed the 5.6.2 and got everything working again…
    Rob
    PowerPC G5 DP2, FCP 5.1.2, Decklink HD, XserveRAID
