Activity › Forums › Adobe Premiere Pro › Will CS5.5.2 projects open in CS5.5?
  • Will CS5.5.2 projects open in CS5.5?
    Posted by Patrick Simpson on May 30, 2012 at 4:12 pm
    I know that PP CS5.5 can’t open CS6 projects; however, I’m looking to update from 5.5 to 5.5.2 and I need to make sure that my coworkers still on 5.5.0 will still be able to open the 5.5.2 projects.
    Patrick Simpson replied 14 years, 3 months ago 5 Members · 7 Replies
  • 7 Replies
  • Chris Borjis
    May 30, 2012 at 4:18 pm
    I have not tested that, but It should.
    cs 4 can open cs 5.5
  • Jeff Pulera
    May 30, 2012 at 5:36 pm
    A better question would be, why don’t your coworkers update to 5.5.2?
    Jeff
  • Patrick Simpson
    May 30, 2012 at 6:19 pm
    You’re right. It’s just that you never know when you’re going to run into someone who hasn’t update yet and we need things to just work.
  • Chris Borjis
    May 30, 2012 at 9:56 pm
    xml export should work between any version I would think.
  • Mike Molenda
    June 1, 2012 at 1:01 pm
    I frequently work between two machines, one running CS5 and one running CS5.5. They are cross-compatible: I can open a CS5.5 project in CS5 and vice-versa. A dialog will pop up noting that the project was created in a different version, and asking you to save a copy under a new filename.
    I’d be surprised if 5.5.2 to 5.5.0 didn’t work similarly, if it even makes a fuss about it at all.
  • Todd Kopriva
    June 12, 2012 at 11:23 pm
    This should work. If it doesn’t, please tell us with a bug report. https://www.adobe.com/go/wish
    But why haven’t your coworkers installed these important bug-fix updates?
    product manager, professional video software
    After Effects team blog
    Premiere Pro team blog
  • Patrick Simpson
    June 13, 2012 at 1:29 am
    Our company has our computers locked down pretty tightly for security as far as updates – so I’m actually still on 5.5.0 myself.
