Activity Forums Adobe Premiere Pro will cs4 project files run in 1.5?
  • will cs4 project files run in 1.5?
    Posted by Anthony Tripe on October 12, 2011 at 1:42 am
    Hi my buddy started editing this project in cs4 but now i have finish it. but i’m only running pr 1.5. Will I be able to do it with 1.5? Will it read the project file. Yikes I’m also open to any other suggestions. I also own a coppy of vegas pro 9. Be nice…
    all the best
    anthony
    Anthony Tripe replied 14 years, 10 months ago 2 Members · 2 Replies
  • Jeff Pulera
    October 12, 2011 at 2:12 pm
    Hi Anthony,
    You won’t be able to go backwards, sorry. This IS supported between CS5.5 and CS5, but not the older versions.
    Jeff Pulera
    Safe Harbor Computers
  • Anthony Tripe
    October 13, 2011 at 3:04 am
    Hey thanks for that info it was what I was afraid would be the case. As an option could he make a AAF file in CS4? Then I could use it in Vegas. Vegas has an AAF import option. Then I could finish basic editing and lock picture then send it back to him to do all effects, sound and sweetening in PPR and After effects. Do you think that will work? I’m going to try that this weekend and I let you know if it works. Thanks
    all the best
    anthony
