Activity › Forums › Adobe Premiere Pro › will adding a second Nvidia4000 speed up rendering
Posted by Anhtu Vu on November 7, 2012 at 2:26 ami’m running PP CS6 on a 12 core Z800, 24 GB ram, Nvidia 4000 and AJA K3G. I was wondering if i would gain more render speed by adding a second Nvidia4000 ? Thx
Paul Thurston replied 13 years, 10 months ago 4 Members · 3 Replies -
Angelo Lorenzo
November 7, 2012 at 5:50 amI don’t believe so. If anyone else can chime in, I think Adobe is currently only optimizing for one gpu card in terms of Cuda. With that said, the gpu only renders so much of the process; this is independent of the fact you may be using gpu optimized plugins like colorista or neat video.
Angelo Lorenzo
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks -
Walter Soyka
November 7, 2012 at 1:51 pm[Anhtu Vu] “i’m running PP CS6 on a 12 core Z800, 24 GB ram, Nvidia 4000 and AJA K3G. I was wondering if i would gain more render speed by adding a second Nvidia4000 ? Thx”
Angelo is right — you will not gain additional render performance adding a second Quadro 4000 in Premiere Pro. Premiere Pro does not support multiple GPUs. (I should note here that After Effects’s new 3D ray-tracing renderer does support multiple CUDA GPUs, so a second Quadro will improve your performance there.)
However, Premiere Pro does support the Maximus configuration: a Quadro GPU plus a Tesla processor. Here’s some linkage:
https://blogs.adobe.com/genesisproject/2011/12/nvidia-maximus-and-premiere-pro-cs5-52.html
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Paul Thurston
November 7, 2012 at 4:48 pmThe answer is no. Folks have tried using an Nvidia Quadro 2000 with two Nvidia Tesla C2075 cards with success, yet that requires a motherboard that can handle the bandwidth, number of cards and a program that can take advantage of the setup. My understanding is that at the moment, you can do similar speed work with just a single Nvidia Quadro K5000 card (PNY VCQK5000-PB.)
Paul Thurston
Producer
Chile
