Activity Forums Adobe Premiere Pro Will a ThinkPad Edge E330 with i3 cpu 12 GB ram and no GPU acceleration practically benefit from an SSD vs. HDD for PPro CC?
  • Will a ThinkPad Edge E330 with i3 cpu 12 GB ram and no GPU acceleration practically benefit from an SSD vs. HDD for PPro CC?
    Posted by Yair Bartal on September 11, 2014 at 5:59 am
    Thanks for any info.
    Ivan Myles replied 12 years ago 2 Members · 3 Replies
  • Ivan Myles
    September 11, 2014 at 12:59 pm
    Yes, but it depends on the quality of the SSD. (Preferred brands are Samsung, Crucial/Micron, and Intel.) During normal operation the application frequently writes and reads small files. SSDs have faster response times than spindle disks. This becomes especially important when writing and reading to the same drive. Will you have a second drive for mass storage, or just the system disk?
    As an aside, you will have a hard time processing 1080p video given the laptop’s specs. A better CPU is strongly recommended.
  • Yair Bartal
    September 11, 2014 at 1:08 pm
    Thanks Ivan,
    I already have that laptop which can only have one disk.
    I consider replacing the current 500GB HDD with this one:
    https://www.amazon.com/Samsung-Electronics-2-5-Inch-Internal-MZ-7TE500BW/dp/B00E3W19MO/ref=sr_1_1?s=pc&ie=UTF8&qid=1410376357&sr=1-1
    The question is in fact if I should go for it.
  • Ivan Myles
    September 17, 2014 at 7:01 am
    Yes, but you might need a supplemental drive via USB 3.0 for mass storage.
