Activity Forums Adobe After Effects Will a Project imported into another Project Update changes?
  • Will a Project imported into another Project Update changes?
    Posted by Fred Matthews on March 14, 2016 at 6:38 pm
    I have a lot of small Projects that I use in numerous larger Projects and from time to time I make adjustments for various reasons.
    Is there any way to have that Project update in the Projects that it has been imported into? Or do I have to delete and re-import it any time that I make a change?
    Fred
    Walter Soyka replied 10 years, 5 months ago 2 Members · 2 Replies
  • Fred Matthews
    March 14, 2016 at 8:08 pm
    That’s what I figured you were going to say. When I re-import it should the bigger project recognize it and just replace the old with the new or is that again something that I will have to do manually?
    I think I know the answer but I just want to be sure that there isn’t a setting somewhere that I can change to take care of these issues.
    Thanks, Fred
  • Walter Soyka
    March 14, 2016 at 8:33 pm
    You can try this:
    https://aescripts.com/project-sync/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
