Activity Forums Adobe After Effects wiggly outlines
  • wiggly outlines
    Posted by Dustin Ward on October 28, 2009 at 10:02 pm
    I’m trying to get that wiggly edge animation where it looks like something is drawn, but the edges are moving. I have a drawing that I am trying to make the edges rapidly move, but not just on the ones near the alpha channel… all the edges.
    Kevin Reiner replied 16 years, 10 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    October 29, 2009 at 7:49 am
    THe SCribble Effect is probably what you need but it works with masks. IF your edges are not along the Alpha Channel, then you’ll need to draw on the edges using the Pen Tool.
    HTH
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Kevin Reiner
    October 29, 2009 at 5:57 pm
    Maybe play with Auto-trace,
    1. Apply autotrace to your picture.
    2. Find a good setting that traces your art they way you like it. (clicking preview helps)
    3.Then check the “apply to a new layer” and hit okay
    4. Apply the scribble effect to this new layer and change the following settings:
    a. check “use all maskes”
    b. make fill type “center”
    c. edge width a low number like 2
    d. stroke color black
    e. stroke width 2
    5. Then precompose that solid layer moving all attributes into the new comp.
    6. Add the displacement map effect to the original image and set the displacement map layer to be the precomp.
    7. Play with all the settings in both effects to get the look you want.
    Hope this helps. It will probably take some trial and error, but might get you to a solution.
    System Setup (for a more detailed list, see my profile)
    HARDWARE
    Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
    9GB Memory
    Two 16x SuperDrives
    Dual-channel 2Gb Fibre Channel PCI Express card
    Apple Cinema HD Display (23″ flat panel)
    ATI Radeon X1900 XT Graphics Card
    AJA Kona LHe SD/HD capture card
    Apple Xserve Raid 5.6TB
    SOFTWARE
    Mac OS X 10.4.11
    Final Cut Pro Studio 2
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum 5
    Sapphire Plug Ins
    Roxio Toast
    Digital Anarchy Anarchist Suite
    ParticleIllusion 3.0
    Trapcode
    Zaxwerks
