Activity Forums Adobe After Effects Expressions Wiggling Fractal Noise
  • Wiggling Fractal Noise
    Posted by Y. Bar on December 22, 2009 at 6:21 am
    Hello,
    I would like to wiggle the “offset turbulence” property of my fractal noise effect, and to do this every 3rd frame.
    What is the correct expression for this?
    Thank you ,
    Y.
    Dan Ebberts replied 16 years, 9 months ago 2 Members · 3 Replies
  • Dan Ebberts
    December 22, 2009 at 8:19 pm
    I’m not sure this does what you want, but it seems to do what you’re asking for:
    f = timeToFrames();
    if (f%3 == 0) wiggle(1,100) else value
    Dan
  • Y. Bar
    December 23, 2009 at 7:57 am
    Thanks for replying..
    I will try to be clearer –
    I have an animation layer (image sequence) which is time streched to 300%. So the image in my animation changes every 3 frames.
    Now the Fractal Noise effect which I added to this animation changes every single frame , due to the Wiggle Expression which controls its Offset Turbulence property.
    I would like this property to change with the Wiggle effect, but only when the image itself changes- meaning every 3 frames.
    I appreciate any help in this,
    Y.
  • Dan Ebberts
    December 23, 2009 at 3:18 pm
    Ah, something like this maybe:
    t = framesToTime(Math.floor(timeToFrames()/3)*3);
    wiggle(1,100,.5,1,t)
    Dan
