Activity Forums Adobe After Effects Expressions Wiggle Y + ease + hold position
  • Wiggle Y + ease + hold position
    Posted by Henrique Bispo on March 6, 2015 at 2:56 pm
    Hello!
    I’m trying to make a bunch of null layers wiggle regularly in the Y axis and hold their position for about 10 frames before they start wiggling again. I also would like the motion to be smooth, so I guess it would be a good idea to have an “ease in – ease out” motion every time the movement starts and stops.
    On top of that, if possible, I would like to smoothly animate the frequency parameter on the wiggle expression through a Slider Control effect.
    So far I could only get the wiggle in Y direction expression working:
    x = transform.position[0];
    y = transform.position[1];
    w = wiggle(1, 200);
    [x, w[1]];
    My ultimate goal with this is to have a bunch of points wiggling so I can connect them later on with a beam effect.
    Does anybody have a clue on how to write this expression?
    Thank you!
    Henrique Bispo replied 11 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 7, 2015 at 3:45 pm
    I think I would approach this by coming up with an algorithm to manipulate the time (5th) parameter of wiggle(). That makes it relatively easy to manipulate the speed, or to hold on a particular value, then continue on. The details would depend on the details of your design–what causes it to hold, range of speeds, etc. A bit of work, but definitely do-able.
    Dan
  • Henrique Bispo
    March 7, 2015 at 6:21 pm
    Uhm.. I never really explored the possibilities of the time parameter in the wiggle, but it seems to be a good approach to the problem.
    I’ll definitely look into it.
    Thanks Dan!
