Activity Forums Adobe After Effects Expressions Wiggle with fixed intermediate values
  • Wiggle with fixed intermediate values
    Posted by Alexey Bobrovsky on August 5, 2016 at 12:21 am
    Hello!
    I need some help in my current project. I’m making a cg semi-realistic eye that has to look from side to side randomly. So I try to use “wiggle” for this purpose. But the actual eye works you know quickly changing its point of view and fixing in the direction for a moment. In the project the eye is actually a sphere where rotation is linked to null object position and an iris animation is done by reshape effect with Percent linked to null’s [x] scale value.
    I’m not that good with expressions… So is there a way to write a script that would perform random life like behavior of the eye? Like “look right, stop, look other direction, stop; iris enlarges and stays this way for a longer time or changes its size depending on the direction like looking up – squeezes on bright light, looking down – enlarges”?
    Thanks 🙂
    Sphere rotation [x]:
    thisComp.layer("Null 1").transform.position[1]*-1
    Null object expression for position:
    wiggle(5, 20)
    Kalleheikki Kannisto replied 9 years, 11 months ago 2 Members · 4 Replies
  • Kalleheikki Kannisto
    August 5, 2016 at 2:09 pm
    Here’s one possibility. With this position expression Null 1 moves randomly to a new position at random intervals.
    seedRandom(index, true);
    x_motion = 100; // maximum motion on x axis
    y_motion = 50; // maximum motion on y axis
    x_pos = value[0] + random(x_motion) - x_motion/2;
    y_pos = value[1] + random(x_motion) - x_motion/2;
    min_hold = 5; // minimum number of frames to hold eye in one place
    max_hold = 25; // maximum number of frames to hold eye in one place
    t = timeToFrames(inPoint);
    while (t
    Rather than trying to fit an ease expression there, I bailed out to using a second null with this expression to slow the motion from one place to another:
    smooth_frames = 2; // how many frames in each direction the motion is smoothed
    smooth_pos = [0,0];
    fps = 1/thisComp.frameDuration;
    for (i = -smooth_frames; i <= smooth_frames; i++){
    smooth_pos += thisComp.layer("Null 1").transform.position.valueAtTime(time+i/fps)}
    smooth_pos = smooth_pos/(smooth_frames*2+1)
    Now you can get your eyeball motions from Null 2's position.
    Not exactly pretty in terms of code, but it will do the trick.
  • Alexey Bobrovsky
    August 5, 2016 at 10:28 pm
    Thank you very much!!!
    As soon as I will finish my project I will share results!
  • Alexey Bobrovsky
    September 8, 2016 at 12:01 am
    Hi and thank you once again! You help had a great value to me.
    I’ve promised to share the results and here they are: https://www.youtube.com/watch?v=5VHpPUx-x3Y
    I think I should make some remarks, technical and artistic.
    Technical: what you see is a concept of statue which is currently assembled in Kiev art center. The eye is actually a led screen one square meter. Random animation supposed to be at least one minute long and should separate four different “emotions”: crazy, tears, love and logos O_o , but the customer (girl who generated the idea of a statue) said that “one minute is so too long, make it quicker”.
    Artistic: “…”
    I wonder what you would say about the statue?
    P.S.: If you ask me I’d say I did a strange video for a strange installation (or I should rather say a big plastic piece of sh@t :-)) )
    September 9, 2016 at 6:58 am
    It’s certainly eye catching…
    Senior Graphic Designer
