Activity › Forums › Adobe After Effects Expressions › Wiggle taking precalculated value as its starting point?
  • Wiggle taking precalculated value as its starting point?
    Posted by Blake Goulette on September 12, 2022 at 2:13 pm
    This has probably been answered elsewhere, but I’m probably not working my searches correctly. Here’s what I want to happen:
    I have a rotation value randomly assigned to a layer through other expressions. I want to add a wiggle expression that takes that precalculated rotation as its starting point and wiggles based on that, not the default rotation (which is always 0). Whenever I add the wiggle expression, it always uses the default (0 degrees) rotation, not what I’ve assigned it through expressions. Here’s what I’m doing that isn’t working:
    seedRandom(index, true);
    r = thisComp.layer("n. Global exp. controller").effect("Rotation multiplier")("Slider") * random(0, 359);
    wf = thisComp.layer("n. Global exp. controller").effect("Wiggle freq")("Slider");
    wa = thisComp.layer("n. Global exp. controller").effect("Wiggle amp")("Slider");
    transform.rotation = r;
    wiggle(wf, wa);
    Blake Goulette replied 4 years ago 1 Member · 1 Reply
  • Blake Goulette
    September 12, 2022 at 2:15 pm
    Never mind, I’m just mathematically challenged! All I had to do was add the wiggle result to the value assigned to “r” (above) and things behave as I want. Thanks for reading!
    (Changed my last line to this):
    transform.rotation = r + wiggle(wf, wa);
